Under the settings menu there is an option "Default Vals" that will restore the radio settings to factory default. But this will NOT affect the programing.
Clearing all the programming would be much quicker using the software. In the "Scanner/SD Card" menu there is an option "Prepare Scanner Memory/SD Card For Use", this will wipe your current configuration and set it up for a fresh start.
Hope that helps,
Keith
