PSR 800 help needed
jacon12
macon, ga.
I purchased this unit and have been pleased with it so far. Since it is my first scanner I can't compare it to others but I found setup on it to be fairly simple..... except for some parts of the included software program. For the life of me I cannot figure out out to edit objects in my scan lists from within the program. I can access Scan list 1 and see everything listed there but can't select any of them and even if I could the 'Remove Channel, Delete Channel and Clear Skipped' buttons are greyed out and cannot be used. I would particularly like to be able to set different colors for the tri color led from within the software instead of in the scanner menu like I have been doing.
Is this possible?
What is possible to do with the software?
Thanks for any help or advice.
Jarrell
stetsonbob
Canton, OH
Is this possible?
Jarrell
Jarrell, You need to click on conventional frequency or trunked radio systems tabs at the bottom of the screen. Then just click on the object so it is highlighted, there you can edit anything you like. Hope that helps.
jacon12
macon, ga.
Bob, that is exactly what I needed to know. Thank you very much for your help!
Jarrell
