PSR-800 LED Question
Arizona_Scanner
Phoenix, AKA HELL
Is there a way to tell the scanner to turn off ALL LED functions, and then turn them back on at a later time, without having to manually change the settings for all objects?
DaveIN
Founders Curmudgen
West Michigan
You can use Stealth mode, but you would still need to drill down into the menu and turn it off again.
Arizona_Scanner
Phoenix, AKA HELL
Thanks, that's what I had suspected. The wife loves to hear the scanner at night as we fall asleep (as I do) but sometimes the LED light gets to her. I think I will simply create a vscanner folder where everything is the same as the one I want to listen to, except for the LED function being turned off on all objects. It only takes a few seconds to load a v scanner after all.
DaveIN
Founders Curmudgen
West Michigan
Actually, I had to look at the OM again. It appears that you need to turn the ALERTS function off, but you could still use the Vscanner to do a switch I guess. Stealth is attached to the Light modes only and not the LED. Maybe you should try both modes (Stealth, Alerts) and let us know.
Arizona_Scanner
Phoenix, AKA HELL
You were correct, one only needs to turn alerts to off, or even audio only to get rid of the LED.
Thanks.
Bob_61
Enfield,Ct.
Stealth mode
I have my 800's light set to to go on for all objects when receiving activity on battery power and all the time on ext power and led set only for the main objects I monitor. When in stealth mode on batteries nothing lights up, nothing. When using ext power the back light stays on, BUT only the priority channel's led lights up. Again that is in B52 stealth mode! :)
