PSR-800: PSR-800 Limit Search Delay Time
CanesFan95
FL
How do you set the amount of delay time for doing limit searches between 2 frequencies? When it stops on a frequency, I want it to stop longer than 2 seconds. Same thing with the Spectrum Sweeper. I want it to stay put longer when it finds something.
Wackyracer
Press pause
CanesFan95
FL
Well sure, I could press the Pause || button, but I don't see a way to set the number of seconds for the delay.
KS0USA
Topeka, KS
If your using the Whistler software with your PSR 800, there's a "Dwell" setting located beneath the "Trunked Radio Systems" TAB. The default setting is 0.8 and I have mine set at 2.0 seconds, but you can go as high as 25 seconds.
I took a look at the Grecom EZ scan and didn't see a "delay", but then I didn't look real close either.
AC2OY
Belleville,New Jersey
I just tried from the keyboard. Couldn't find it. I assume it has to be done from ezscan. I could swear you could change the delay time from the scanner itself. There has to be a way if I figure it out I will post it.
KS0USA
Topeka, KS
Yes, it's showing and available in the Whistler EZ scan - it's the last column under the "Trunking Radio Systems" TAB. I could not find that same arrangement or listing within the Grecom EZ scan.
KS0USA
Topeka, KS
I re-installed the Grecom Digital Interface to include the cpu etc. The only delay I can see available under "General Settings" over in the right-hand column and that's referring to Priority Settings and delay, which it appears the default there is 2.0 seconds.
Might be interesting to load up the Whistler EZ Scan and then dump your configuration etc. from the PSR 800 into the Whistler EZ Scan and then use that setting under the trunk area for delay you want and test the scanner to see if it applied.
ADDIT: I found your delay and most like what you saw in the past - if you pull up one (individual) scan list you will see "Dly" - it's the seventh column going from left to right. You can set the delay for each individual station you have in a particular scan list.
CanesFan95
FL
Yeah, I'm not seeing anything in the GRE software that lets you do this. And can't find anything in the radio menus. I thought "dwell" time refers to how long the scanner reads a control channel before moving on to another trunking system control channel if you're trunktracking multiple systems. I'm referring to conventionally searching a limit / range between 2 frequencies.
KS0USA
Topeka, KS
This is using "GRECOM" EZ scan -
ADDIT: I found your delay and most likely what you saw in the past - if you pull up one (individual) scan list you will see "Dly" - it's the seventh column going from left to right. You can set the delay for each individual station you have in a particular scan list.
jkahn
Very good looking Member
Silver Spring MD
But that doesn't work for a limit search though, does it?
If you are using a modified PSR-800, you have to use the Whistler version of EZ Scan anyway, but I think everyone is talking about P25 dwell time and Priority scan delay.
I do not think there is a variable delay for search scanning that I have been able to find. I do the same thing, set search limits and then scan to find new activity. Unfortunately the PSR800 is not the best radio suited for that.
I use one of my Unidens (Extreme software versions) to search scan and log, then dump to the computer.
JK
