Hi all!
I have tried repeatedly to make my 800 scan conventional frequencies but I'm having zero luck. The scan list is enabled and I can browse the objects in it, however, when I go to scan them it says "Nothing to scan". My trunk groups scan just fine, conventional frequencies not at all.
I'm running the latest 1.5 firmware and the latest Ez scan software. Any help you can give me is greatly appreciated. Thanks in advance!
EDIT:
I should also note that nothing, so far as I can tell appears locked out, such that the scanner should skip it.
Regards!
Sent from my ADR6425LVW using Tapatalk 2
EDIT:
Regards!
