PSREdit: psr edit new to me need help
savage308
Belleville , ontario, canada
for some reason win 500 wont open for me so i downloaded a trial of psredit it opend for me , i downloaded from scanner , how do i edit my scanlists i highlighted a frequency i wanted to lock out i pressed the lock out button nothing happened, i tried to put my cursor behind the frequency to back space to remove the numbers nothing no cursore was flashing what am i doing wrong
hiegtx
Dallas, TX
Are you getting an error message? If so, what does it say?
If you are getting a "Data Execution Protection" message, see post 22 in this old thread.
In PSREdit500, select the tab that fits what you are wanting to change. For a conventional channel, select the Conventional Objects tab. For a Trunked System talkgroup. select the Trunking Objects tab.
Find the item you want to edit & double-click on it.
That will bring up an Edit screen where you can make your changes. This example is for a conventional channel.
Be sure to hit "Apply" to save your changes.
savage308
i double clicked on scanlists i got the scanlist screen i selected bank 1, then i highlighted number 14, it went blue i double clicked on lockout nothing happened only ting it allows me to do is completly remove the scan list number 14 , i cannot back space or place a cursor on it and chnage the frequency like i could with win 500
hiegtx
Dallas, TX
It sounds like you are trying to edit a channel using the drop-down Scanlist menu box:
1784138273210.pngThe only thing you can do on that menu edit screen is set individual scanlists to either be scanned, or ignored (not scanned). You can choose (using the "Select Fields option) what details are shown on that screen, but you cannot edit the individual settings.
If you use either the conventional objects screen (as noted in my earlier post), or trunking objects screen, you can edit to add, or delete individual objects, as well as change the scanlist that specific object is assigned to. You can also edit or assign other items, such as the alert led color, and backlight operation. You can assign a specific object (conventional channel, or trunked system talkgroup) to be part of a single scanlist, or multiple scanlists.
You also did not elaborate on what, if any, error messages you were seeing when trying to use Win500.
savage308
i went a paid for some pc help, stupid microsoft, i got the win 500 back on my pc up and running , borrowed my old scanner downloaded the scan lists got the 1040 up and running again tried to save the scanlistfor a backup coming up as the scanner monitor instead not the scanlist of frequencies where am i goin wrong
savage308
igot win500 to download finally with some help ,i have a conveobject list of all the frequencies on the scanner on the main page i want to save them to the win folder for reference later, when i try to save them to folder what gets saved to folder is the scanner monitor control , not the frequencies, what am i missing
hiegtx
Dallas, TX
There are three software programs for programming the scanners based on GRE's original models PSR500 (handheld) and PSR600 (Desktop/mobile). These are the same as the current Whistler-manufactured versions WS1040 & WS1065. There are also two sets of the same models, which were sold at Radio Shack under their product numbers.
The software programs are Win500, PSREdit500, and ARC500. There is a User Guide in the Wiki for ARC500. There are two different User Guides online for Win500. One from Utah Radio, in the web archive, another posted originally by Whistler.
None of these three programs allow you to selectively save only the programmed conventional channels. oe only the trunked system objects, nor the Scanlists. What you can save is a complete programming file, including all the programed conventional and trunked system objects, as well as the scanlist settings. You can then use the saved file to program your, or an additional scanner of the same model series.
It's not clear, from your posts, exactly what you are wanting to do. Apparently, initially you had problems getting Win500 to run, but a later post indicates that someone helped you resolve that. In Win500, you can open up the file with conventional objects, and highlight all of them, either using your mouse, or using the Windows shortcut <CTRL>+<A> to select the entire list, then copy that to the clipboard using Wndows <CTRL>+<C>. Once you have those copied to the clipboard, you can then paste them to a text file using <CTRL>+<V> and save that file. Is that what you want to do?
tvengr
Well Known Member
Baltimore County, MD
After you go to the Scanner tab and Download from Scanner, go the File tab and click on Save As, name the file, and click on Save. It will be saved as a P500 file.
