kruser
Hi,
I've had fairly success here with a simulcast 800 P25 system when using the PSR-600 or 500.
I see an option to change the P25 setting from Auto to Manual.
Can anyone point me somewhere that explains this in greater detail?
I'd like to play with the manual settings but I'm not really sure where the settings are changed.
For example, I see in both Arc500 and Win500 how to change the P25 mode from Auto to Manual but I don't see where one would change any settings when you set a system too manual.
I do see threshold Hi and Low settings for each system in Arc500 but those also exist for conventional systems so I'm not sure they have anything to do with a P25 setting of manual. I do not see the threshold settings at all in Win500 unless I just overlooked them.
If anyone can explain the manual P25 settings too me, that would be great!
I have one system that I'd like to play with just to see if it can be improved any as far as decode errors go but I'm lost as to what gets changed when I select Manual P25.
Thanks!
Thanks!
