PSR500 Deaf to Phone Patches
letarotor
Arlington, TX
My PSR500 will recognize radio to radio private calls as advertised, but it will not recognize phone patches on a Moto Type IIi TRS. I even programmed in the radio IDs as private talkgroup objects that we use for the private call phone patches and did some tests, the scanner is deaf to the IDs in this mode. Can anyone explain or have any theories as to why this is so? Thanks.
RKG
Boston, MA
For what it is worth, my PSR detects (as "private calls") telephone interconnects.
The SmartNet system handles a phone call function as a private call channel grant request to a UserID that is associated with the MRTI, so I don't see why the PSR would distinguish between private call channel grants based on the ID of the target (which it has no what of knowing is addressed to the MRTI).
mikey60
Oakland County Michigan
In P25 systems, the telephone interconnect channel grants are a totally different message than the private call channel grants. The Update messages are also different, although the formats are similar.
Mike
RKG
Boston, MA
OK; the system I'm referring to is a SmartNet system; I didn't realize the OP was referring to P-25s.
DonS
Franktown, CO
AFAIK, the O.P. only referred to a "Moto Type IIi TRS". I'm pretty sure that doesn't indicate a P25 system.
letarotor
Arlington, TX
It's not a real big deal because the feature is not used that much anymore, I'm just curious why it won't work on our system. The experts I've talked to suspect it might be a status bit issue?
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
That's incorrect. The format used is different than talkgroup calls. Status bits are not used.
Interconnect can be difficult to locate on some systems as the late entry message can be misconstrued (as noted above) as a Private Call, to put it simply. I'm not exactly sure how the logic works for PC's and the GRE but it may work in your favor by accident.
