moonies
I have been working with this scanner since thanksgiving,and have a problem with the v-folder set-up. I used to own the pro96 which allowed you to erase a state info which you didnt want and rename and reprogram that bank with any info/systems you wanted to configure. This scanner seems to prohibit this so once you erase or delete a folder it remains empty?? I understand scan lists and having the v-folders as storage areas, but how do you manually input sysytems into a blank folder from the units main memory???
