At least if you are using a standard comport it does indeed worked and has for a long time.
Please remember something - just because you may go in the scanner and set CC DUMP ON, that doesn't mean it stays on. And if you are depending on UT turning on CC DUMP, that isn't going to happen if you dont have the scanner plugged in via the USB cable and already communicating with the computer.
1. Are you on a standard comport (even nonstandard ones should work, at least up to a certain number) ?
2. Have you already tested your USB connection between the scanner and computer (using some other software like PSREdit or Win500)?
If so, proceed. If not, do this.
3. If you go into PROG/FUNC/GLOB and scroll down to the bottom, is CC DUMP ON?
If so, proceed. If not, turn it ON
Then do this:
a. unarchive a pristine copy of the latest version of UT (or UT RETRO) into a brand new directory
b. make sure your scanner is plugged into the USB cable
c. make sure the USB cable is plugged into the computer
d. make sure that other programs can communicate with the scanner via the USB cable
e. turn on your scanner and make sure once more that CC DUMP is on
f. fire up UT (running out of the new directory)
g. Set up the receiver (look at my screenshot below)
- make sure you select the valid comport (my cable isnt plugged in right now so the screenshot doesnt show it)
h. turn on the receiver
See if that works.
Mike
