PSR600 & Edison NJ TRS
Richard
Florida
Has anyone using a PSR600 been able to "track" the Edison NJ Police Talkgroups using the Custom Trunking Tables listed in the database? I realize that the PD is encrypted and even if tracked cannot be monitored. However, the radio refuses to recognize or hit on any of the PD talkgroups even though I am able to track and monitor the FD/EMS transmissions. My BCD396XT properly tracks the entire system using the same Trunking Table. Thanks!
Richard
Florida
No. I have a number of other systems programmed which stop on an encrypted talkgroup and log a hit.
robbinsj2
Bridgewater, NJ
My Pro-106 (clone to the PSR-600) skips over encrypted transmissions on Motorola trunked systems, which is what Edison is. It does not, if memory serves, skip encrypted P25 trunked transmissions.
Jim
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Jim
Your memory is correct Jim. Pro-96/2096 does same thing. Skip on MOT but not on P25.
Richard
Florida
I suppose that's the answer. It is a Motorola encrypted system. Seems odd though that P25 systems at least show activity on the talkgroup but the PSR600 shows nothing. The manual merely states that the radio will not receive encrypted transmissions. Thanks to all for your help.
de784
Delaware
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Could be like Delaware that uses encrypted but they also use secure even with the ids entered the scanner does not stop on those talkgroups
W2SJW
Senior Member
Northwest NJ
Motorola Type-II systems have status bits, P25 systems do not. The GRE's (and RS clones) are simply ignoring any transmission with a status bit of 8 or higher.
