PSR600 & Unitrunker 1.0.0.5
xml
Just bought a new PSR-600...
I can't seem to get either versions of Unitrunker working with either a P25 and Type II system... I'd like to use the CC dump that's built in.
I'm pretty sure my PSR settings are right as I can use Pro96Com with a P25 system without any problems (via USB / CCDump)
Here are my settings in 1.0.0.5:
Type: Inline (no option to select GRECOM)
Model: PSR600
Role: Signal
Run: Running
Serial: COM3
Baud: 115200
Data Bits: 8
Stop Bits: 1
Parity: None
... everything is dead.
--- Anyone had some success?
Thanks!
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Also, you need to make sure CC Dump is on. I think UT will turn it off when it exits, and I think that when you fire up UT and start the receiver it will turn CC Dump ON as long as you had the USB cable plugged in and the scanner on when you started UT.
I could be wrong about that - but if those are the same exact settings you use for Pro96Com, then there is no other reason for UT not to work unless you don't have it configured right and have CC Dump ON.
So...
1. Make sure CC Dump is ON immediately before you turn the receiver on in UT
2. Make sure you have the receiver in UT configured as 'inline'
3. Make sure that you have UT set to decode Motorola and P25 in the decode options
Mike
xml
Cable was flashing, just no data.
Dumped a new UniTrunker install in a different directory and everything is working great.
Thanks Guys
g5turbo81
Cedar Rapids,Iowa
I'm having the same issue here. I have he Pro 197. I turned CCDUMP on. Connected the USB Scanner/PC Interface Cable ( Cat No. 20-047) up and set as the directions suggested. I tried to download the site from Here, and it would not let me. It came up at the Download screen with my credentials, and all I recieved was the Talk Group ID's. Where do I start? I used the newest version I found of Unitrunker.
I am attempting to monitor the Iowa City,IA PD Motorola Trunked site.
Acer Aspire 5570Z notebook.
Windows Vista.
I have it as PSR600
UT
Running
Serial: COM3
Baud: 115200
Data Bits: 8
Stop Bits: 1
Parity: None
I use Win500 as well....Any help would sure be appreciated.I'm lost here...
Matt
Highpockets
Toms River, New Jersey
Windows Vista.
I have it as PSR600
UT
Running
Serial: COM3
Baud: 115200
Data Bits: 8
Stop Bits: 1
Parity: None
Matt
I don't know if this will help, but you can take a look at it:
UniTrunker Guide - UtahRadio
g5turbo81
Cedar Rapids,Iowa
Tried it...Currently, Control Ch. is 860.26250. I have it in remote mode on WIN500 to make sure the cable is working...System is 3323. It won't alow me to import from RR, and I am pretty sure I've got it all set up according to what that Link you sent me suggests.
