I've noticed on my PSR800 that the clock does not maintain very good accuracy.
It gains about three to five minutes every 24 hours.
I don't hook it to the computer very often so after say a month, my PSR800 clock is between 90 and 160 minutes or so fast.
I may update it via ezscan once per month and always set the clock at the same time.
Does anyone else notice this fast clock?
I don't really worry about it but it does mess me up when I use the radio for recording. The timestamp will be way off when I go back to find something I'd heard earlier. I know it is a scanner and not a glorified clock but for something that timestamps audio files, I would think it would have a much better clock accuracy.
I do not run it from battery power very much but I do allow it to charge maybe once per week so it is not caused by the batteries going flat.
I usually use an external usb adapter and not the computer for a power source.
I just find it odd that the clock gains so much time in a single day.
I hope the radios PLL reference oscillator is not coming from the clocks oscillator!
It gains this time in all power modes. When running directly from batteries, hooked to a charger but the charge time has expired so not charging and when hooked to a charger and charging and of course when powered on and scanning which would not be charging or when hooked to a computer for updates.
edit: Not having a service manual for this radio, I'm not going to try and find what controls the real time clock as that circuit could very well be part of some master oscillator for the entire radio but I did do a temperature test to see if it was something temperature sensitive and it appears to not be changed by its ambient temp. I put it in a warm fridge at about 46 degrees F for 24 hours and still found the same time gain when I powered it on.
