PSR800 Frequency Display w/ EZ Scan
WeldGuy
Canal Winchester, Ohio
I'm learning how to program my new PSR800 using EZ Scan on my laptop. I'm having trouble getting any trunked systems to work. I thought I followed each step and carefully selected the correct data for each step, however none are working for me.
Here's a big clue... when I select the "Trunked Radio Systems" tab and select one of the systems I have programmed, should I see frequencies for that system listed in the window to the right titled "Site Frequencies?" All the frequency lines are 0.000000
What did I miss???
Thanks for the help.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Click on the site
WeldGuy-
You need to click on the site... hope this helps.
WeldGuy
Trunking Issues
Geeeez... never overlook the obvious!
This digital stuff is a little tuff to master for a guy who grew up with crystals. I guess if I was able to learn how to "tweak" a crystal by either shaving it a little or adding pencil lead I'll figure this out too.
I may be back with other questions before this is over.
Thanks.
lebrunmn
I did the same thing when I started working with this scanner/software... I'm like you: I started with a four channel crystal scanner from Sears, way back when. We fossils have to stick together!
Please let me know if you have any other questions--if I don't know the answer, there are lots of folks in the forums with extensive PSR-800 experience--they've certainly helped me.
Take care,
