I just went through the manual again and didn't see any mention of 'patch' showing on the display between TGRP and psdr. I only saw it once yesterday during a EMS patch to a hospital. So maybe someone here can explain this?
Then last night my scanner started acting nuts. Kept showing different TGID numbers with the same TGID name. I formatted the card today as specified by GRE. Uninstalled the software and installed it again. Did the CPU/DSP/Software updates released today. All was well for a while but then start to do it again...
On the same TGID, so I'm wondering if its something odd the system I'm monitoring is doing. I have no idea. It will stop on TGID 12 with the name, but then 'patch' will flash to the right of TGRP on the display and the TGID # will change between 11 and 12 but the TGID name will stay the same. I remember this also happened when listening to the EMS patch last night, the talkgroup changed between the hospital and ambulance.
I've only had this scanner a month and have been away from scanning for quite a while but never saw a 'patch' behavior in the local P25 system here for police and fire. I don't know what they would be using it for since its in the TGID's for police. Last night it showed 4 different TGID #'s for this same TGID name. Which was even more confusing.
So I'm just asking if anyone else has seen this and what could be happening. It seems its not so much a problem with the scanner. Although I never in the past month had this problem, or activity on that talkgroup that has been causing the trouble. Last night the activity began and so did this odd behavior. Maybe not so odd but new to me. Thanks.
