psredit500 help
topcat60
Douglassville pa
I decided to buy the psredit500 . I got the talks groups working finaly. But when i try to add more freq it erases the talk group.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
I sounds like you went back and added the frequencies but failed to recheck talkgroups. If this is true you have created a second TSYS with same name (Reading or Montgomery Count) but the second is without TG's
To avoid creating a second TSyS, Edit the first and type in the additional frequencies.
mikey60
Oakland County Michigan
Are you starting from a clean configuration when you try to add more frequencies? The GRE scanners operate in complete configurations when uploading to the scanner. If you want to add to what's there, my suggestion is to download the configuration that is in the scanner, add what you want, and then re-upload the new configuration to the scanner.
Mike
khoelldobler
now residing in Ocala, Florida since 1999
topcat, call me at home... I'm in Ocala, Florida. 352-369-4326 I will turn on my PSRedit500 and go thru it with ya to help ya figure it out. Its around 1:45 pm, and I'm here if ya need me. I will be here, I've helped many RR members figure out thier programming issues using PSRedit500 software. I feel PSRedit is the best way to go. Please call me and we will get ya thru it. Take care, Kevin
WayneH
Forums Veteran
Super Moderator
Your master site
Moved to Scanning Software. Topcat, please be aware that questions in the RadioShack forum are to be directly related to the scanner. Questions about a software application be it programming or unrelated should go in to one of the Software subforums. Thanks for your understanding.
