psredit500 import from RR
foxtail
Niagara Region Canada
Using above soft, when I try to import bell fleet trunk, I select say 2 sites. Import system. After that psredit goes to tsys config. From there I pick complete import but nothing show under trunk info. This is with newest ver. of psredit. Can't see what I am doing wrong. It did fill once but not sure what I did to get it and info was not what I want so I del. it. Looked at the help file but it doesn't give much info for import. Hope someone can help. Thanks for your time.
foxtail
I did after playing with it for sometime. Do I need to do anything with the wildcard parts where it lists your banks with a check mark? Need to know if I should pick a wild and what it does? Thanks again.
mikey60
Oakland County Michigan
The wildcard allows you to hear talkgroups that you have not specifically programmed into the scanner. Using them is a matter of personal tastes.
Mike
