LMRN Technical Data Discussion
Muxlow
Super Secret
Middlesex County
Correct. For now they are. If you see a cruiser with the black whips rather then the chrome ones, then they have the new radios. Roof UHF antenna will be shorter also.
Wretched
Perth County, Ontario
Picking up Sierra Oxford County units on 772.1312 this evening… must be a car local because that’s a pretty large distance from me for a repeater otherwise.
hunterca
SDS150
Ottawa
If the VR's are in the 700's, I guess the C Control channels are also the same. Meaning more ugly towers have to be made because of the high frequencies? Does the BCD325P2 cover the 700 band?
gary123
Picked them up too on 772.13125 with a PL 88.5. Very noisy, so I was unable to id the user as EMS or OPP.
Muxlow
Super Secret
Middlesex County
Control channels are VHF. The "old" VR's were UHF in the 412 MHz ish range for the portables. Similar here, but rather then it being in the 400MHz, its 700. VHF for the trunked system on the car radios and 700MHz for the portables.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
This is the known P25 table for PSRN:
P25 Channel ID Table
CH IDTypeBase (MHz)Spacing (KHz)Transmit Offset (MHz)
1FDMA136.005000.0075-4.02
2TDMA136.005000.0075-4.02
3FDMA136.005000.0075-4.05
4TDMA136.005000.0075-2.235
5FDMA136.005000.0075-2.235
6TDMA136.005000.0075-2.145
7FDMA136.005000.0075-2.145
12FDMA769.000000.00625+30.0
13TDMA769.000000.00625+30.0
14FDMA851.062500.00625-45.0
15TDMA851.062500.00625-45.0
gary123
As the hunt for DVRS freq's continues, I am starting to see a pattern. Each frequency per service seem to all use different PL tone. This might be a way to identify a new find.
ATCTech
Picking up Oxford Units in Tillsonburg on OPP BEAT02 772.14375 I also had them on 771.1400 the other night.
That second one would have to be either 771.13750 or 771.14375 according to a 6.25kHz step bandplan.
Muxlow
Super Secret
Middlesex County
Just took a trip to northern Ontario. Didn't find any new P25 control channels. Most OPP cars past Barrie all had the old antennas. Even a trip through Orillia, almost all cars had the old style antennas and the UHF BEAT and VR's still in use. No action at all off 700MHz
ATCTech
142.845 is active with 1038Hz test tone, very weak here in Halton County but decoding like all the rest (TG 1, RID 1) when not being clobbered by FleetNet transmissions. I'm guessing it's not Cedarwoods based on that being the sole known assignment of the freq. in zone 1 which is active with FleetNet voice traffic. The RF level of the P25 carrier is also more than 20dB lower than the FleetNet transmissions from here too and it's fading quickly as the sun rises.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
772.13125MHz with a pl of 88.5Hz is definitely coming from Alliston.
772.15625MHz was rebroadcasting Caledon calls so it's most likely a Bolton BEAT repeater.
gary123
The existing MOH and 700 MHz frequencies may be common across the province.
