PTT Release Tone
ambdrvr
Release tone
Hello,
The answer is no, the PTT release tone is a radio wide feature. So if you check the box for the PTT release tone it will be present of all channels.
Ambdrvr
N2ZPY
Delaware County NY
What I do on mine is just set one DTMF tone as the end of transmission. This way you get a simple beep when you unkey the mic. This should be able to be set on each channel. I know it can be on the old TK272.
Kevin
ramal121
Sonoma, CA
Kevin
Is this what you're trying to do? If so:
First, go to EDIT>OPTIONAL FEATURES>COMMON PAGE 3. Under PTT ID, set PTT ID TYPE as DTMF, then put a single digit in END OF TRANSMISSION.
Second, go to zone(s) and channels(s) you want to enable this for. Click CHANNEL EDIT and then set PTT ID as EOT (end of transmission).
You should be golden.
SCES
I tried that, but it didnt seem to work
