I would agree with what several others have mentioned. Your best choice is one of the three
suggestions from
RaleighGuy as well as other suggestions for one of the SDS series scanners.
The
Montgomery County site is simulcast.
Simulcast distortion is difficult, if not impossible, to deal with with anything other than the SDS series scanners, the Unication pager, or using an SDR dongle on your PC. It can be extremely location specific. If by chance or luck, your location is exactly correct, the out of sync signals from the multiple subsites (transmission towers) might be attenuated enough by terrain (hills), taller buildings blocking some of the signal paths to your location, or perhaps something specific to your house like metal siding or foil backed insulation in the walls combine to allow you to find a specific place in your residence where the scanner would work, But that is rare, And none of these apply if you are using a handheld scanner when out & about in the city. More on simulcast, and suggestions on what might help, in certain specific, but rare, instances are on this page in the Wiki.
Simulcast digital distortion - The RadioReference Wiki
The
Dayton site is not tagged as simulcast, but I suspect that might not be correct. There are two licenses listed on the sites detail page. One,
WQQH916, only applies to the 700MHz frequencies on the site. There are three sites, one in Montgomery County, and one in each of two different counties.
The license listed for the 800MHz frequencies on the Dayton site, WQYD437, is
expired. Spot checking that set of frequencies for licenses in your county show new licensing, with the frequencies at multiple sites in the area, so while the site is not designated as simulcast in the database, I suspect that is actually is because of the new licenses. So, I would treat it as simulcast as well as the county's site.
Should you still want to try a scanner other than the suggestions for receivers that can deal with simulcast (the SDS, Unication, & SDR), then I would suggest that you make your purchase from a dealer that will not charge a substantial restocking fee if it does not work at your location and you want to return it. While some sources (not all) will ship to you free, in most cases, none (other than Amazon) will pay return shipping. (Amazon does that for Prime accounts.)
