Push Error 105
ecollins11
Ada, Oklahoma
When I connect Scannercast V0.14 10307) I get a ScannerCast push error 105 HTTP/65535.65535,505 version not supported content-length:163 What does this mean ? ScannerCast stats shows RR Connection ERROR Not Connected,
rick3d
Wilmington MA
I'm getting the same message...... I moved the scanner to another computor because I am having a low audio on the other. I can't figure it out either?
ecollins11
Ada, Oklahoma
I even went into the cable modem and router and set up the ports for scancast an I still get that error. On my feed page the status shows coming soon wonder if that has anything to do with it. I have the net framework installed on the computer and with my broadwave audio server i can run 2 streams with no problem.. I am going to look aroung and see if i can find any info on that error.
ecollins11
Ada, Oklahoma
Here is the Error log of ScanCast
01-Nov-2011 17:11:07 ScannerCast V0.14 (10307)
01-Nov-2011 17:11:07 Server Stopping Sound Capture.
01-Nov-2011 17:11:07 Server Final Cleanup.
01-Nov-2011 17:11:07 Exception: System.ObjectDisposedException: Safe handle has been closed
at Microsoft.Win32.Win32Native.SetEvent(SafeWaitHandle handle)
at System.Threading.EventWaitHandle.Set()
at System.IO.Ports.SerialStream.AsyncFSCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
01-Nov-2011 17:11:07 Server Stopped.
