Puslinch Fire
Anyone know what Puslinch fire is using in Wellington county for the trucks and portables? They page on 153.7700 but they are not coming up on fleetnet or on 153.7700
ATCTech
And nothing on the other Wellington County FD VHF frequencies in the database here?
Nope, I am going to have a listen to some of the small LTR systems in the area if I am in the area again in case they are there.
mciupa
Moderator
From Industry Canada:
Code:
4 record(s) retrieved.
Search Results Tx Frequency (MHz) Rx Frequency (MHz) Class of Emission-1 Frequency Status Station Location Licensee Name Call Sign
153.770000 153.770000 F3EJN 6 ABERFOYLE ONT. Township of Puslinch Fire Department XJH522
153.770000 153.770000 F3EJN 6 PUSLINCH TWP. ONT., Township of Puslinch Fire Department
154.070000 154.070000 F3EJN 6 ABERFOYLE ONT. Township of Puslinch Fire Department XJH522
154.070000 154.070000 F3EJN 6 PUSLINCH TWP. ONT., Township of Puslinch Fire Department
How about on FleetNet on Guelph's talkgroups?
EJB
20 + year membership
Downtown Hamilton
Some of Wellington Co Fire services are now on Fleetnet, not sure about Puslinch.
ATCTech
What about this old thread?
http://forums.radioreference.com/ontario/244437-new-tg-fire-fleetnet.html
And this, which I think is from 2010/2011:
http://www.wellingtonadvertiser.com/index.cfm?page=detail&itmno=8630
It specifically says Puslinch was not part of the agreement with Bell at the time, but that has no doubt changed.
Checking my Unitrunker logs, I see t/gs 21120 and 21168 have appeared on my system in the last 3 weeks as well. They're not in the db here but they are in the proper range to be associated with Wellington County.
The Wellington Advertiser - Township council gives approval to fire dispatch changes
Apparently it is an LTR system, 400 Mhz, Possibly Kenwood portables.
Code:
153.7700 paging but operations on UHF apparently. LTR
mikewazowski
Forums Manager
Oot and Aboot
I remember something about Erin Fire being on a Passport system somewhere around 420MHz.
There are a couple of passport LTR;s listed in the RR DB for business use, one is only two channels to that might be it, will have to put the frequencies into the scanner conventionally and see if I catch fire transmissions. The dispatch and the fire halls were on 153.7700 but not the trucks and portables.
ATCTech
Confirming tonight that an in-progress fire call for Rockwood Fire Dept. appears to be on the M R C Systems Inc. trunk licensed to the location of Puslinch Nickrock tower in the TAFL.
Frequencies are 420.1125 / 420.2125 / 420.3125 / 420.4125. Audio is decoding with DSD+ DMR/TRBO mode enabled. I haven't had a chance to see if this system is cross-coupled to the M R C Systems Inc. site (different frequencies of course) over near Brisbane (Erin) or not.
I don't think this system is in the database here yet. More data to follow but for now the call has been terminated. Page-out for the call was on 153.770. I would expect the Puslinch Fire Department will be on this one too.
ATCTech
That it is Mike, and 158 is the correct ID on closer inspection of the datastream. Brisbane site frequencies are 420.5875 / 420.6875 / 420.7875 / 420.8875 and 420.9875 per the TAFL, with Brisbane being just a touch west of Erin.
ATCTech
Nope, that Rockwood call last night was ending just as I found them and I've been doing ATC-related real work all day. I'll record 153.770 during the evenings this week and see if I can grab the different departments conducting pager tests so we know who we might be looking for.
Bob
Bob
Rockwood has it's own talkgroup on Fleetnet and I have heard them use it so it is just Puslinch we are looking for, keep in mind those LTR passport systems might not work on the scanner in trunking mode, you might have to put the channels in conventionally and most of the talking will be on the first channel anyways.
mikewazowski
Forums Manager
Oot and Aboot
It's not Passport, it's a MotoTRBO system which ATCTech is quite good at deciphering.
ATCTech
It may not have been Rockwood, the timing was very coincidental but in researching the one street name I heard it does not cross-reference to Rockwood. It does however show up as a street in Fergus, and it was a Pumper 20 that I heard. If anybody knows which department has a Pumper 20 that could narrow it down further.
Thanks for the compliment on deciphering TRBO, however I am confused as to what frequencies belong to what system when I'm seeing things in the TAFL that don't seem to jive on the air. For example, 2 of the 4 freqs. listed as the MRC system in Puslinch have the regular momentry pulses of an LTR system. From what I read with Motorola, one can be upgraded to the other. Could that be a clue as to what it what up there?
mikewazowski
Forums Manager
Oot and Aboot
Rockwood does have a Pumper 20. Fergus is part of Centre Wellington and is Station 40.
I'm wondering of the two systems can coexist? Set each system up so the shared frequencies are only used when the system is extremely busy?
mikewazowski
Forums Manager
Oot and Aboot
Another thought is the Fleetnet talkgroup that has been reported is a patch between the TRBO system and another fire department in the area.
