I have a problem but I'm not sure if it is caused by the EZ Scan software or the PSR-800. My county uses a 770 MHz system operated by a neighboring county's 800 MHz controller. Both systems are P-25. The Site Options > Trunking Tables needs to be set for "Auto Fill". This is located at Trunked Radio Systems tab > Trunked Radio System > Trunked Site Info > Site Options >Trunking Tables.
My problem is that whenever I make a change to the system like adding or deleting Talk Groups or Setting the Record option, the Trunking Tables option changes from Auto Fill to Standard and the scanner won't scan the system. This doesn't happen with any other P-25 system.
Has anyone had this problem and what did you do to correct it?
Jack
N8BSR
Jack
N8BSR
