PWRgate system installation
Avery93
Marion County, AL
Alright, I've decided to build a power supply system around the PWRgate PG40S charging a battery that is powering my radios. This is the first time I've ever done anything like this and I need some serious help.
Obviously I will need a battery, a power strip (RIGrunner 4005 or 4004) and a regulated power supply. Anything else?
Now, I'm wondering what kind of battery I will need. I am wanting to power 2 possibly 3 receivers for a day or two without AC power. I was looking at these AGM batteries but have no idea which model to get. Obviously the longer lasting the better but I don't want to spend much over $100 on one.
Next I need to know what kind of regulated power supply to get. The PWRgate manual says when using AGM batteries the power supply should be adjusted to provide 14.5 volts, so I need one capable of doing this. Also, how many amps would it need to produce for this setup?
The RIGrunner 4004 looks interesting because it also appears to be capable of charging my blackberry, is this possible?
And finally, since the radios will always be running off of battery power, does this mean they will be somewhat isolated from power surges and possibly lightening?
I'm sure its very obvious, but I just wanted to state that I'm a complete noob when it comes to stuff like this.
Thanks for any help!
AK9R
Lead Wiki Manager
Super Moderator
Central Indiana
Cable to connect everything. Powerpole connectors. The Wireman has some nice heavy-gauge red-black zip cord. It's similar to what we used to call "machine wire" in that it has a tough coating over the PVC insulation. I bought the ratcheting crimper that West Mountain sells for Powerpoles. It's expensive, but perfect crimps every time. If you try to crimp Powerpoles with a pair of pliers, you'll risk mashing the connector so it won't fit in the Powerpole housing. I tried a single-action Klein crimper, but it was tricky to get a good crimp.
The Powerwerx batteries look expensive to me, but prices may have gone up since I bought mine. Do you have a Batteries Plus near you? They can fix you up with a AGM battery of the type used in large UPS's and you won't have to pay shipping.
How big of a battery is dependent on your load. Add up the receive current for all of your radios. Any transmitters? Figure them in using a ratio of something like 90% receive and 10% transmit. Take the total current load and multiply by the number of hours you want things to run on the battery. That will give you the amp-hour rating you need. Mulitply by a safety factor of at least 150%. That's the size battery you need.
For example: 5 radios each drawing 1 amp on receive. That's 5 amps total load times 48 hours equals 240 amp-hours. That's a lot of battery.
Here's a link with more information: How to calculate battery run-time when design equipment using batteries; Battery Technical Resources for Design Engineers from PowerStream
You'll need a power supply with an adjustable output. The VS series from Astron will do the job. How big is dependent on how quickly you want the battery to recharge. Remember that unless you have frequent power outages, the power supply will be just float charging the battery.
Yes, the USB port on that Rigrunner is designed to power or charge devices that use a USB cable for charging.
Power surges, yes. A direct lightning hit can cause a lot of damage no matter what you do. It's lightning, by the way, not lightening.
