Pyramid SVR-250 Questions…
BMDaug
I am licensed…
Central Colorado, USA
Ok. So I have an SVR-250, VHF with tight reject filter 1602 and pass filter 1604. I have the cable for use with the XG100M/CH100. Does anyone have the pinout for the FY-4 programming cable? It’s a db9 to rj11 cable for programming the unit. Also, is anyone familiar with the SVR250CPS? Is it available from Pyramid? Is it expensive? I’m excited to get this unit set up for SAR missions and the programming is the last piece of the puzzle.
Thanks for reading!
-B
ramal121
Lots and lots of watts
Calif Whine Country
Go to the Pyramid website and download the service manual. Loads of information and it shows the programming port on the schematic. You can also search a local dealer to get the software from.
BMDaug
I am licensed…
Thanks! I have read through the service manual and it is indeed very useful! I was about to download the data sheet for the component that the rj11 connects to on the schematic as there is no cable pinout for the programming cable listed anywhere, but someone posted a pinout on another forum.
I’ll give a dealer a call and see if I can get the software. It’s the last piece of this puzzle!
Regards,
B
BMDaug
I am licensed…
So I ended up just calling pyramid directly and within minutes, I confirmed the pinout from the other forum and received links to download the software! Excellent support!!!
-B
BigLebowski
Piedmont NC
So I hate to drag up an old thread but how are you liking the SVR-250 with the Unity mobile? Was it plug and play with the cable?
BMDaug
I am licensed…
It all works as expected/advertised. I had to move some jumpers (solder particular sets of pads on the PCB) to set it all up for the Unity. I think it was used with a Moto previously. But ya, it works great and a cable would be easy to make if you can’t find an OEM one. I have a TPL amp that could boost the 2W out of the pyramid, but I haven’t messed with that yet.
I’m actually thinking about getting another one in a different band just for more interop, but I’m also considering just tying two of my 100Ms together and making an all-band patch. The SVR250 really is great, especially for the used price, but it would be absolutely awesome to be able to do P25C with AES on input and output and on any band.
-B
BMDaug
I am licensed…
Um. If you need an amp, you're doing something wrong.
Not when the use case is filling a gap in coverage for SAR teams in remote areas… I’m not at a 10,000sqft crime scene. I’m covering 10sqmi, so two watts isn’t gonna get where we need to go. Now, if power was on par with a 5-6W portable, then fine, but it’s not, so the amp will take 1W from the SVR and boost to 10W, then factor in losses through the cavity filters and I’m hitting right around 6-7W…
-B
mrsvensven
I think you're better off with a higher gain antenna and maybe even raising the antenna on some sort of a mast. Your portable radios probably aren't actually putting out a 5W ERP unless they are VHF with a 12+ inch long antenna.
I'd only try the amp if you've already done this and still have problems hearing the SVR250 output, but not problems getting into it.
BigLebowski
Piedmont NC
@BMDhow does it work as far as activating it? From the touch screen?
I have a 700mhz SVR-P250 on the shelf I haven't done anything with yet.
WRTI285
-B
Would you mind sharing this information as I have purchased a used svr and need to program it?
