Q for the motorola gurus about cloning.
Stretchman
South Florida
Hey all. I have 2 6550s that I am trying to clone. I am hoping to only have to write one code plug, and have it the same for both radios. One of them has connect plus purchased for it, and the other doesn't. They came from E-bay that way.
I do have legit MOL software and a wideband key. Is there a way for me to get this to work so that I don't have to have two saved codeplugs? When I try to clone the radio, it won't let me write from the radio that has connect plus to the radio that doesn't.
Also, when I was on the train today coming back from the VA, the radio let out a high pitched squeal. I turned it off and back on, and it didn't happen again. I've heard this is a thing. Firmware is 1.2.17, and I am using version one cps.
TIA.
PS - Picked up a 2500 mah battery from sandown wireless. Seems to be working good.
K9RPL
Western Burb's of Chicago
IFAIK the two radios must be identical. The fact that once has CP and the other doesn't is why. As for the squeal, that's a fault in the 1.12.17 firmware. There is a fixed version (1.17.08) but it was never available on MOL. It's out there though.
GTR8000
NY/NJ Database Guy
BEE00
If you have an MOL account and have purchased the TRBO software, contact MSI and ask them to send you the 6550 firmware S01.17.08, which fixes the full volume high pitched squeal.
Stretchman
South Florida
I had them send me the file. It is in the directory, but for some reason, I cannot load it from the cps. I even tried a recover on the radio, and tried again. No joy.
Stretchman
South Florida
Did you run the executable? That installs it into CPS. Once it's in there you can do Device => Update, then select the firmware to load.
Did that, and it's in the directory, but it doesn't show up in the drop down when I go to run the upgrade.
Stretchman
South Florida
Pingback, since I contacted Motorola solutions and re downloaded the firmware file. Seems the last one I received was corrupted. I installed the new firmware file, and both radios have updated successfully.
Also, I found when I programmed the radio with less features and then cloned the device to the radio with more features, I was able to clone successfully. So, from now on, I will be able to only write one codeplug instead of two.
Thanks to all who helped.
rescue161
KE4FHH
Hubert, NC
It is always good practice to keep a codeplug backup of each radio. If you ever get into a situation, like a FL01/82, you can write with an original codeplug, but you will not be able to clone to recover that radio.
Stretchman
South Florida
That's good advice too. Not too difficult to save a copy after cloning. Thanks.
merlin
DN32su
Why can't it be that simple for the XTS5000. the XPR6550 was easy.
