Hi all,
my first post here at Radioreference (what a brilliant site - have learnt so much from you all)
My apologies up front if I am asking an "old ground" question but, I tried searching older posts and hopefully have done my homework in this respect here. Happy to do more if I've missed the obvious.
I have an Excalibur G31DDC and I've finally tried creating a memory file using the CSV format for bulk entries and using what was suggested in the Winradio on-screen help (quite basic info that seems to make sense if it all worked)
I've found that when entering freqs in MHz all is well but when trying entries with kHz, come post import load time, I just get a memory file with everything in MHz. So for example, if I put in 12345kHz I end up with 12345MHz effectively and the radio just tunes to the 30MHhz end of the spectum uselessly.
I'm running the latest Winradio load v 1.61
Has anyone had any luck with trying the CSV memory load or recently?
Cheers,
Wotsup
Cheers,
Wotsup
