Quansheng firmware not allowing CHIRP upload after uploading eugzmer v0.22
KR3E
Gaithersburg, MD & Punta Gorda, FL
After successfully uploading the egzumer_v0.22 firmware to my K5, to improve reception of the aircraft frequencies, and then trying to upload a new file from CHIRP (driver v2.01.33), I get the message "Firmware version not supported by this driver."
Suggestions for correcting this problem?
prcguy
Do a search with egzumer and chirp, there might be a file you drop into chirp that allows it to work. I had the same problem with IGV v2.95 and was pointed to a file I have to run with chirp for that radio/ firmware combo.
JustLou
NY/NJ
This shouldn't be necessary anymore if you're using the latest version of Chirp as it now has egzumer support built-in.
KR3E
I'm ok now. It turns out that when I used CHIRP's "query source" function to downloaded from Radio Reference that file failed to contain a required header. By downloading my original content from the radio, cutting and pasting the downloaded frequencies and info into my original file, and re-loading it back into the radio all is well
