Quansheng UV-K6 with broken/choppy audio
Farrenc
I've had three UV-K6 radios and all three have had this problem: on receive, the audio is sometimes broken/choppy. The meter will show a solid signal, but the receiver drops out -- green receive light goes out. If I push the monitor button to open the squelch, it stops the problem. Here's a video of it happening with another radio next to it working perfectly:
Any ideas?
Thanks!
-Farren / KB0AZJ
merlin
DN32su
I think the signal is too hot. Maybe a few Db attenuation at the antenna input.
Supposedly, the boards in the K6 and K5 are identical and my K5(8) doesn't seem to have that issue.
Already noted somwhere that parts are wide tolerance so no two radios will be exactly the same.
nd5y
Wichita Falls, TX
Receive audio chopping and the squelch closing on voice peaks like that on a real FM receiver means the modulation peaks of the signal being received are exceeding the receiver passband.
That means either the transmitter is overdeviating or the receiver bandwidth is too narrow or both. If the receiver is set to NFM or Narrow then set it to FM or Wide and see if it imporves.
On a crappy CCR direct conversion transeceiver on a chip it type radio without real IF filters, especially if it has hacked firmware, there is no telling if it's a narrow bandwidth issue or something else.
Farrenc
Well, the radio is set to Wide so that doesn't seem to be the problem.
Are any of the alternative firmware options better for problems such as this?
