Thanks again for your help! That’s what I’m gonna do… Please just to help me understand though… the state uses 30MHz and 45MHz offsets in the ~800MHz band. Isn’t this pretty close to the same actual spacing (using a unit of measure like centimeters) as 7MHz in the VHF band? My frequencies are ~152MHz and ~159MHz. I’m not sure what words to use to properly convey what I mean. Ya, you’re talking about 30-45MHz, but that’s with little tiny 800MHz wavelengths… I’m at 7MHz offset with much like longer wavelengths. Does RF not work this way?
I’m not trying to argue with you, here. I’m going to take your build advice for sure, I’m just trying to learn.
Thanks,
Brian
700MHz LMR band is 30MHz spacing
800MHz LMR band is 45MHz spacing.
You could run separate antennas on VHF, but you would need the filtering to keep the TX out of the RX. Since you are not using a trunked system with TX combiners with filtering and RX multicouplers with filtering, you still need to have some filtering. That's where you either need a lot of vertical separation or the duplexer.
The duplexer works much better than vertical separation since it keeps the TX and RX antenna in the same place so the coverage is the same. It also means you don't have to pay for two antennas and two feedlines on the tower. Some tower sites might charge you per antenna linear foot and for each run of coax up the tower. Usually duplexers are cheaper.
With 7MHz of separation, you shouldn't need super expensive duplexers.
