Quantar PL Help
vhfuser
Acquired a Quantar VHF repeater All is well, but I cannot get it to generate a PL tone on its transmit. All the settings appear to be correct although there is no specific "Activate TX PL" type setting in the RSS. It accepted the codes ok in the menu that did reference PL. We do not require PL to access the repeater but we desire to have PL on its TX at all times including hang time. This is standalone, no external controller (yet) What did I miss?.
vhfuser
Problem solved
I found that the Quantar does not generate the PL tone if the Quantar TX is keyed using the front panel PTT
button.
It is generating the tone in repeat mode. Whew!
ramal121
Lots and lots of watts
Calif Whine Country
All the higher end Motorola repeaters do that. A PITA if you want to hail a radio via the local mic.
