Quantro Port
itji
Hi folks,
I wonder about the orange port on the back side of my quantro, any one know about this port? is there any port to use for linking the quantro to other side ?
thanks in advance
DY
RocketNJ
Pequannock, NJ
Are you referring to the 8 pin plug in back? That's for wireline connections (if you have a wireline board installed).
1 Line 1 +
2 Line 1 -
3 Line 2 +
4 Line 2 -
5 Line 3 +
6 Line 3 -
7 Line 4 +
8 Line 4 -
itji
Oh well, I am Actually looking for COS signal, is there any where I can find in this radio? I don't have any manual with me.. :-(
RocketNJ
Pequannock, NJ
The 50 pin connector is what you want. Pin 32 is ground and pin 37 is RX code detect. If you program the Quantar for PL + Squelch for RX activation then that will be the qualifier for that output. When using an external controller on my QUantar it required me to invert the signal (a transistor to invert the logic).
itji
Okey then on pin 32 and pin 37, I will got COS, will I got PTT on this port too?.. I plan to use computer, so I can link my quantro through VOIP such as eQSO etc.. and use the 4 wire line that I got Installed as the audio port.. is it possible ?
RocketNJ
Pequannock, NJ
I've sent you the Quantar field manual which details the pinouts. That should get you going.
You can look into using the MRTI connections for the VoIP interface. I've done that with external repeater controllers.
itji
Thanks Dave, I've got your email.. I look forward to get to know much about this equipment.
DY
