question: 2 scanner antennas co phase?
jpsartre26
Hello everyone!
Does anyone know if it is safe to connect 2 base scanner antennas to one radio? Also, is it safe to connect 2 scanners to 1 antenna?
Thank you
N8IAA
Fortunately, GA
Yes to both. On the second one, don't use a "T" connector. Find a multicoupler. That way, the radios will not interfer with each other.
HTH,
Larry
popnokick
Northeast PA
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_1_3 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B329 Safari/8536.25)
http://m.radioreference.com/forums/GetThread.php?t=105054&bat=
http://m.radioreference.com/forums/GetThread.php?t=113057&bat=
D
DaveNF2G
Guest
Co-phasing isn't necessary (or cheap). The antennae would have to have different phasing cables for each band, which involves either a lot of fast switching or a lot of signal loss.
If you want to do diversity reception, then you need an external device for that, too.
Boatanchor
Hello everyone!
Thank you
Depends what you want to achieve.
Co-phasing typically refers to two or more antenna elements operating on the same band. The aim is to obtain higher gain, by beam steering/concentration. Co-phasing relies on careful antenna spacing and tuned phasing lines (typically 75ohm coax for 50ohm antennas) to ensure correct phase & impedance matching back to a single 50ohm feed line. Because 'tuned' lengths of coax are used to join two 50ohm antennas to the feed line, co-phasing only works on a narrow band of frequencies (+-5% from the tuned frequency). Get things wrong and performance can be much worse than a single resonant antenna.
Multicoupling on the other hand, is a different kettle of fish.
This is where two or more antennas or radios on different bands are connected to a common feed line/coax. Each antenna/radio is isolated from the other antenna/radio by the use of High pass, Low Pass or Bandpass filters.
Multicoupling works very well and single or double stage LC High pass and Low pass filters are relatively easy to build and can be housed in a small IP66 die cast enclosure.
For example,
If you wanted an efficient 35Mhz antenna as well as good VHF Hi/UHF performance, it is relatively simple to build a 2 port diplexer/multicoupler with a 80Mhz cut off frequency. Then you can connect a resonant 35Mhz antenna (vertical dipole or similar) to the LPF port, a discone on the HPF port and a single low loss coax coming back into the shack. In the shack, you can either run the single coax into one scanner, or build another diplexer of exactly the same design, to split the 35Mhz signals to one scanner and the VHF hi & UHF signals to another scanner. Either way, it gives good performance with relatively low loss (the diplexers should only introduce ~1dB of loss each, which is barely noticeable).
I should also point out that running two scanners from a single coax using a simple coax 'T' connector can be problematic. It will work OK for stronger signals but you will see at least 3-6dB signal reduction on all signals/bands and much greater attenuation on some signals. In addition, since there is no isolation between the scanners, any noise or interference generated by one scanner will degrade reception on the other. Ideally, you should run a dedicated 50ohm power splitter/combiner, which will provide 20-30dB isolation from one scanner to the other and will prevent any interaction.
N8IAA
Fortunately, GA
Why are we confusing the OP's question with co-phasing? All he asked was if he could connect two external antennas to one scanner. Yes, he can. Can he connect multiple scanners to one antenna, yes he can with a multicoupler. I don't remember reading about a phased array in his post.
Larry
n5ims
Larry
Read the original post again, especially the title, which is "question: 2 scanner antennas co phase?". If you read closely, you'll notice that the last two words prior to the question mark are "co" and "phase". Perhaps this is what may be leading folks to assume that they're asking about co-phasing antennas.
N8IAA
Fortunately, GA
I did read the title, and the questions in the body of the post and answered his questions.
Larry
