LIScanner101
My old but “still new in box” Monitenna is, as many of you know, a wideband dipole, so it needs a 300-ohm-to-75-ohm balun in order to connect it to traditional RG-6 and F style connectors. This will be used for scanning ONLY (NO transmitting).
Since the cable is, as I suspect, old and inferior to what’s out there today I was considering upgrading to something like brand-new quad shield satellite TV cable. Then I thought – why stop there? Why not upgrade to something even BETTER, like LMR-400 or LMR-600? Less loss, right? Problem is, those are 50 ohm cables. What would happen if I connected these to the balun's output? Would I lose a lot of signal? Is it a “myth” that you have to use 75 ohm cable on a balun when you’re just scanning?
