Baofeng Question about BTECH UV-25X2
BuckeyeGMRS
COLUMBUS
I hoping this is just a setting I have messed up but I can't figure it out and hoped for some help here. I have a UV-25x2 radio I purchased 2nd hand. It has worked pretty well for my needs. It has just developed a strange issue. When someone transmits I can see the frequency change color to indicate someone is transmitting and i'm receiving but the only way I can hear what they are saying is to put the radio in monitor mode. I have tried different levels of squelch with no luck. Am I missing something or should I put my radio in the recycling bin. Thank you in advance
sallen07
Rochester, NY
Sounds very much like you have the wrong receive CTCSS/DCS tone programmed for that frequency. Try removing it and see if that helps.
BuckeyeGMRS
COLUMBUS
I have not been outside to check but Im wondering, I did do a factory reset and I can't recall if I had to re-enter the frequency (GMRS channel 21) Would my radio have forgotten my programmed frequencies at that point or does that depend on the radio?
HavenBTS
Atlantic City, NJ
It sounds like you have a CTCSS or a DCS set on a channel you are monitoring and someone is transmitting on the same channel with no CTCSS or DCS. You will see that someone is transmitting but you will not hear them. The same will a occur if you are on a repeater channel and of course that repeater has a CTCSS or DCS set and your radio has the same set and someone is transmitting on the 462 side on simplex without a CTCSS or DCS. Again, you will see that someone is transmitting but you will not hear them.
