Tden, personally I would not worry at all about using the ~70 Ohm cable with your Icom. Even if there is a mismatch between the transmitter and the coax of a 1:1.5 SWR, that represent a reflected power of <5%. The amount of reflected power seen back at the transmitter's PA will be decreased (burn'd up) by the coax inherent Ohmic losses- and thus pose little strain on the amplifier. Modern transmitters have fail safe thermal run-away circuits to prevent their amplifier's destruction- the most you would see with a badly coupled line would be a decrease in power, as evidenced on your power output meter. At a 1:1.5 SWR you won't see a thing----- A 100 Watt transceiver can well handle 72 ohm coax without the need for any tuner.
Something to keep in mind- 'Coax cable' is just another term for a RF wave guide.... that's where the "RG" in RG-213 (etc.) comes from. While it can be rated at a certain Ohmic impedence- it does not always exhibit that value. For instance: when a line length is in even multiples of half wave lengths, the input resistance will be equal to the load resistance- regardless of the lines impedence. Thus if you have a half wave long (but don't forget the velocity factor in calculating this length) line matching a resistive 50 Ohm antenna, it doesn't matter if the coax is 72 Ohms, it will be a "prefect match."
That was but one of the many quirks of coax'es -- feedlines actually. I am getting a little too technical, No?... sorry
When I get like this its time for an Anecdote.
In my lab we have ten or twelve (I forget how many) 1000 foot spools of Belden 8213 coax. Their origins predate my tenure- but that's over 2 miles of cable !- what its original purpose was to be, I haven't a clue. Anyway, its 72 Ohm, beautiful foam dielectric 1.5db loss/100 feet @100 Mhz's line.... and we have plenty of it. And because we have so much of it, my coax budget is $0- and will probably remain zero for a long time to come (ie: no general purpose 50 Ohm stuff in our future
This cable is used for every routine RF run imaginable- and with very few exceptions, no one questions whether its to match a 50 or a 72 (or there abouts) loads. It works fine, and this spans the gamut of frequencies- from DC to ~3 Ghz, and high powers too.
Its been my experience that few antennas present a perfect "50" or "72" Ohm load. So if, say, your SWR is 1:1.5 with a 72 Ohm cable- 'tweak' the antenna with a little +/- inductance/capacitance- and "Bingo" ---- you can achieve a 1 to 1.
Go ahead and use your 72 Ohm stuff Tden....
......................................CF
