xpawel15x said:
When programming EDACS frequencies you have to program them in order, so do I put the first frequency into channel 000 or 001 ? I have a Pro-97 and the first channel in the bank is 000.
01 - you'll never put an edacs frequency in a 000 or 100 or 200 ... 900.
If your LCNs are 5,7,9,13 , then you put it in 005, 007, 009, 013 for instance.
The same applies with LTR. Anything that is entered based upon LCNs will start from channel 1 (and may not even include channel 1). You put them in exactly the channel that the LCN is - if the LCN is 13, then you put the frequency in x13 (where x is going to be the bank where you are storing all of that sites freqs).
In EDACS and LTR systems, it's not mandatory that a system be set up to use any specific LCNs. So theoretically you could have a 5 channel EDACS or LTR system with LCNs of 11, 13, 20, 22, 24 and you would program them into your scanner in 011, 013, 020, 022, and 024.
Mike
