I'm helping out on a project with a video conference setup that needs to be interfaced to a computer. The cameras use SDI connections over coax cable currently connected to a video switcher. The new addition will be an interface card so the system can be streamed over zoom.
This is the interface card that will be used, it has BNC and SMA connections.
I need to make 2 coax jumpers that connect from the SMA outputs of the card to the BNC inputs of the video switcher.
This is the recommended coax from the camera and video switcher manufacturer,
I already have some BNC and SMA ends for LMR-240. If I order some 75 Ohm 240 cable will this work OK? Or is there something special about this cable for video use?
Would I be better off just ordering some pre-made jumpers from the antenna farm or elsewhere?
1694A - 75 Ohm SDI Coax | Belden
75 Ohm SDI Coax, RG-6, 18 AWG, Solid BC, Foil + 95% TC Braid, PVC Jkt, CMR
catalog.belden.com
