Question about masts
MrRevesz
Mid-Coast Maine
I'm thinking of putting in a mast that's a bit higher then the roof, however I haven't any real idea on where to find masts....
My question is, where do you guys recommend / get yours, and what size should I go? (I'm in a residential neighborhood, and a lot of trees on my property)
KC0QNB
Gothenburg, NE
Radio shack offers two a 10' and a 5'. Tessco offers several telescoping masts, from 20-50'.
How high do you want to go?, how are do you want to mount it, roof of ground? remember if you go over 10 feet it needs to be guyed.
Grog
Banned
West of Charlotte NC
Good idea, but I would love to see a fence that uses 21' posts (non correctional uses :D)
KC0QNB
Gothenburg, NE
The horizontal top rails are 21 feet long not the vertical ones. Just for clarity
MrRevesz
Mid-Coast Maine
Great suggestions, didn't even think of the fence...
I'm thinking between 20 - 40'. I think 20' would be level if not a tiny bit over my antenna mount on the roof, however I think it would be easier to work on and add other stuff to it if I choose on an in ground mast....
KC0QNB
Gothenburg, NE
You might try a tons mast look here He did an awesome job with the whole project.
stevolene
chattanooga metro
I bought 2 10 foot top rail aluminum fence post from ace hardware, I believe the cost was around 16.00 for each section, they slide into each other, you can drill a hole where they meet and put a bolt in there, I wouldnt recomend going any higher than 20 ft with this set up though, not without guy wire
n8emr
One of the few things radio wise radio shack is good for is there TV mast, 5 or 10ft sections. If your only going 30ft they also have a tescopic mast. Lowes and homedepot also have similar mast in the tv section
gcgrotz
Savannah, GA
Heavy wall galvanized water pipe comes in 21' sections too and will support a small scanner antenna. I'm using 1-1/4" with a RS full size cb whip on top for a 40 meter vertical. It is very heavy and needs commercial grade mounting brackets, perhaps mount it to a 10ft piece of 2" that's in 3 or 4 feet of concrete.
ka5lqj
Near Lakeview, LA (Caddo Parish)
Fence Top rail.....
My 2 ¢:
All of the galvinized fence top rail I've bought at Home Depot measures 10' 6" with one end swagged for insertion into the other. They make a connector that goes in-beteween but it's for horizontal mounting of the pipe. If memory serves me right, the top raid O.D. is about 1½".
When I found it necessary to go above the original 10' vertical "stick", I cut a 4' long piece of electrical pvc, 1½ I.D. and slid it in-between joints, drilled holes in the upper "brace" and lower "brace" and bolted it together. It works best if you rotate the bolt hole placements 90º. This makes it mechanically secure.
Above 20', this "bolting" gives you a place to put a guy ring to put the guy wires. I believe they still sell them. I don't think that given the top rail's thickness, even guyed, I would not attempt a 50 footer, LOL!
For that you need to consider a metal tower and the neighbors won't like that. :-(
Respectfully,
73,
Don/KA5LQJ
"I reached into the air, and found a friend."
Viper43
Fence posts are not strong enough, they will bend like pretzels in 50-60 MPH winds. Even the RS telescoping antenna mounts bend easily in 60-70 MPH winds. A heavy duty pipe such as a riser which is in 10' lengths will survive much higher winds, it however isn't cheap. My one pipe post survived the winds from a tornado, just not the tree that fell a half hour later.... I think the pipe was $50 a section, but it will easily survive 90 MPH winds.
V
MrRevesz
Mid-Coast Maine
Not bad, thank you all for your suggestions, I'll probably go out after labor day and start pricing stuff
blueangel-eric
Emporia, KS
V
what's a riser?
