Question about Nextel direct connect
N467RX
Panama DB Admin
Prescott, AZ
Can the Direct Connect be used between a Nextel and a Boost phone? or do the phones have to use the off-network function (short range comms then)
ecps92
Taxachusetts
Nextel and Boost are the same. Just two different marketing Schemes.
ecps92
Taxachusetts
Sprint is it's own Network
Nextel is it's own Network
Boost is the Hip-Hop [and other marketing schemes] on Nextels Network
I've D/C'd folks on Boost from my Nextel.
You could not do the Sprint. Unk if thats changed recently tho
Oh ok. I knew they were both owned by Sprint, but I wasn't sure if they were on the same network.
KE4ZNR
Radio Geek
Better double check with Sprint Nextel on that, I had one person from Sprint about a year ago tell me the two will not inter-communicate.
That person was either
a) totally wrong
or
b) misunderstood what you are asking...here are the facts:
1) You can direct connect between Nextel and Boost as long as both phones run off the Iden network (with the PTT button on the side and require sim cards)....
2) You can NOT direct connect between the CDMA versions of Boost to the Iden Versions on Nextel...at least NOT yet....
3) You can NOT direct connect between regular Sprint CDMA phones to Iden Nextel phones...
4) You CAN use Sprints new Q-Chat on select new CDMA Sprint handsets to Direct Connect between those CDMA handsets->Nextel Iden....but that feature is only available on select CDMA Q-Chat capable handsets at this time...
Hope this helps!
Marshall KE4ZNR
bigray246
Toms River NJ
Sprint/Nextel
FYI my buddy just up-graded his Nextel/Sprint phone and had to change his direct connect #. They are now using your cell phone # as the DC #, no more 175*22*6666 #s. Ray
WayneH
Forums Veteran
Super Moderator
Your master site
You can carry-over your old DC number, you just have to find someone who knows how to do it.
