Question about Pro-97?
k9-cop
Will the Pro-97 display the encode and decode tones while you are just randomly scanning? I have a radio that I am programing but can not utalize the local repeaters as I do not know the tones to access them. Hope this questions makes sense......
NeFire242
Nebraska
Only if it's in CT or DC mode. If the channel is in FM it will not, but if it is set to CT or DC, then yes it will show them. While the code is being displayed if you press Enter it will be stored.
NeFire242
Nebraska
FM it will not decode any tones such as PL, this would be CSQ.
CT is CTCSS which means it will decode PL unless one is programmed in, then audio will only be allowed to pass when that PL is present and will reject all the other unwanted transmissions (intermod).
k9-cop
OK makes sense. So just to clarify, if you put the scanner in CT mode and you do not actually have the CTCSS tone programmed into the scanner for a specific freq, then the scanner will display the tone access code from the repeater when it is heard?
loumaag
Silent Key - Aug 2014
Katy, TX
Yes. And same for DPL (Digital Coded Squelch) if you put it in "DC" mode.
