RDALE,
AGAIN, your WRONG..... try this on for size:
Midland:
Straight from the PDF owners manual found here on PAGE 9:
http://www.midlandradio.com/comersus/store/comersus_viewItem.asp?idProduct=3105
9
Multiple S.A.M.E. County Codes:
Press “MENU” button to open menu options.
• Press the “UP” arrow to scroll through menu options until “S.A.M.E.
SET” is displayed, then press “SELECT” button.
• Press the “UP” arrow to scroll through: “SINGLE”, “MULTIPLE”, or
“ANY.”
• Display “MULTIPLE” as explained, then press “SELECT”.
“S.A.M.E.01” will be displayed, indicating you will be programming your first
S.A.M.E. County Code at weather radio menu location “01.”
• After programming your first S.A.M.E. County Code, press “SELECT” then
the “UP” arrow to advance to “S.A.M.E. 02.” Program all of your S.A.M.E.
County Codes in the same way as above.
• When finished entering all your codes, press “MENU” to
close the programming menu.
Choosiing an Allerrtt Type ((DIISPLAY,, VOIICE,, OR TONE))::
1. Press “MENU” button to open menu options.
2. Press “UP” arrow to scroll through menu options until “ALT TYPE” (Alert
Type) is displayed, then press “SELECT” button.
3. Press “UP” arrow to scroll through the following (3) alert types: “DISPLAY”,
“VOICE”, or “TONE”.
4. Press “SELECT” to choose the Alert Type you want.
5. Press “MENU” to exit menu programming mode.
Allerrtt Type Descrriipttiion off Tone Patttterrn
DISPLAY
When the DISPLAY alert type is chosen, only
a text alert will scroll on the display. There
will be no audible alarm.
VOICE
When the VOICE alert type is chosen, the
alert will sound for 8 seconds, then you will
hear the voice of the weather broadcast for 5
TONE
When the TONE alert type is chosen, the
alert tone will sound for 5 minutes, or until
you press any button except the “WEATHER/
SNOOZE” button which toggles to the
voice weather broadcast.
Notice it says DISPLAY ONLY...... hmmmmm, odd, I get descriptions etc on the screen........not full details but enough...
V
