Question about T4Win
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
With T4win can i listen to digital systems like motorola 3600 baud and 9600 baud and EDACS Pro vocie and open sky? and motorola encrtypted talkgroups. and do i have to have an attenna and an scanner hooked up to my pc in order to use this program? or can i just listen to things through the internet? :?
mancow
N.E. Kansas
Although I haven't yet got it to work here (bad reception area). I can tell you this:
T4WIN is a decoding program. It takes the information streamed out by the actual trunking system's data channel and displays it on a computer. It will show you what is happening on the system in regard to what radios are talking on what talkgroups etc.....
It has an output function that is meant to actually control another receiver so that it can follow the conversations through the system.
It's basically like building a trunk tracking scanner by using one radio to receive the data channel the computer to decode it and control a second receiver to listen to the actual traffic. You don't need the second receiver if you are only interested in "seeing" what's happening on the system or logging activity.
It requires a radio tuned to the data channel with the audio feeding into the computer sound card. You won't hear anything at all you will just see the system operate, unless you have the second receiver connected.
Does t this make any sense?
mancow
ka2mek
Cobra_Commander said:
With T4win --- do i have to have an attenna and an scanner hooked up to my pc in order to use this program?
Yes
That would be a Requirement.I am running it now with a BC895XLT Uniden scanner and Windows XP on a Compaq Presario 1200 with excelent
results.Monitoring Troop "C" Central New Jersey State Police Motorola Type II System.
Very Pleased with this software thus far,Many Many Slaps on DA back to its creators and support group of contributors.
73!
You Know Who
{{{BEEP}}}
