Question about the cable that connects a remote head to the base on a CDM1550ls
JoshuaHufford
Jefferson City, Mo
Is there anything proprietary on the cable that connects a remote head on a CDM1550LS to the radio? It looks like a standard network plug and flat 8 wire connector. If there isn't anything special about it I was thinking about making a custom cable the length I need to get rid of excess.
GmanX
It is 10 conductor connectors and cable
Floridarailfanning
Tennessee
I'm almost certain It uses standard RJ45 terminations with flat category style cable, just with a custom pin-out. The last remote CDM setup I had was several years ago though, so I might not recall that completely accurately!
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If you don’t use the DTMF mic, you can use a standard CAT-5 LAN cable in place of the Motorola 10P10C connector and cable. Others have reported excellent performance in runs up to 100’ or so.
The outboard pins 9 and 10 Of the remote cable are the DTMF control lines and are only needed when using the AARMN4026 DTMF mic.
10 pin is RJ-50.
You can use an 8 pin RJ-45 Ethernet cable without an issue. I've done it on a few installs.
I'm not sure I agree with Steve. I know the 10 pin mic connector has the DTMF pins on the outside, but I'm pretty sure using the 8 pin cable between the RF deck and the control head you loose the handset audio.
I could be wrong though. I have the CDM service manuals, but I don't have one that covers the remote head kit.
mancow
N.E. Kansas
10 pin is RJ-50.
That sounds correct from what I recall too.
