Question about using an external speaker on a CDM radio.
JoshuaHufford
Jefferson City, Mo
If I were to use an external speaker on my CDM1550ls like this,
When you plug it in to the back of the radio does it disable the internal speaker in the radio or do both speakers work?
Can you control the volume of the external speaker with the volume control on the radio head?
KG4INW
Midlothian, VA
Both speakers will work and the volume control will work for both, simultaneously. If you want the control head speaker disabled, you'll have to dismantle the head and physically unplug the speaker. Up to you.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
We’ve talked about this subject with the CDMs many times before. This a very, very good addition to a mobile install and some base station installs.
The audio quality is greatly improved and you’ll have more volume without distortion if needed.
FWIW, I always add the remote speaker on all of my mobile installs for the above reasons.
That's a lot of money for that speaker. But getting it with the 16 pin connector already installed has some value. Be aware, the CDM's have a 20 pin connector, but the 16 pin connectors will seat in there just fine. The two outer pins on each side are not needed and won't interfere with this plug.
The others answered this, but I'll add:
I have several CDM's in use for various purposes. For base use, it's mounted under the cabinet in the kitchen. The internal speaker is loud enough to be heard through the whole house.
In my wife's car, 2009 Ford Escape Hybrid, the internal speaker is fine.
In my truck (F350 Diesel), as well as a Polaris Ranger, the external speaker is a great addition. I can drive my truck down the highway at 65mph with all the windows rolled down and the audio is loud and, more importantly, clear. In the Polaris, I can be riding down a trail at 35 mph with a full face helmet on and the radio is loud and clear.
They are a great addition to any mobile, as Steve said. The larger speaker cone really helps with audio intelligibility.
I played around with disconnecting the internal speaker in my truck. I didn't really notice any difference. If anything, the smaller speaker in the control head added some to the high end audio. I hooked it back up and have left it that way.
JoshuaHufford
Jefferson City, Mo
Fantastic, this is exactly how I was hoping it would operate.
I'm mostly wanting to get some volume outside the vehicle when needed, nice to know it will improve audio quality as well.
Yeah, roll down your windows and crank it up. A CDM with the large Motorola speaker will make your ears hurt. You'll have no problem hearing it outside the vehicle.
