Question about UV5R TDR...bug or change?
LordKaos
Hi!
Well, I'm new in this forum, I read many very useful threads here, so at first thanks for sharing.
I'm a question about my UV5R (Ver BFB297).
I read in some sites that when TDR (menu 7) is ON, the radio should Tx on the last A or B that received transmissions, so to avoid that, we can set a fixed A or B for our Tx in menu 34 TDR-AB.
...well...mine doesn't keep in the last A/B that received...always remain in the one I select....either if I set OFF - A or B in menu 34. No matter what menu 34 option, always transmit in the one I select with the A/B key.
Is that a change in BFB297 or a bug?
Also I take advantage of my post to ask to be sure....the "recovery" images to reset my version are these?
- BFB297 Reset.img
- BFB297(factory).img
...both downloaded from: Index of /uv5r/programming/CHIRPrecovery
Are them the correct?
Thanks in advance.
Marcelo (KAOS)
LordKaos
I didn't find the edit post option, but I wish to add this info:
Chirp says that my firmware is 1FB297 - HN5RV01, but the radio (power on+3) says: BFB297.
;) Thanks
nd5y
Wichita Falls, TX
BFB297 probably isn't the real firmware version.
You need to use Chirp to view it.
Go to Settings/Other Settings read the version shown in Firmware Message 1.
If you load an image from a different firmware version in the radio you can mess it up.
In the past several years there have been several firmware changes that affect how the TDR-AB function works. There is no way to fix that and no way to upgrade or change the firmware.
LordKaos
Hi Tom, thanks for your response.
Chirp confirms that my firmware is: (line1) HN5RV01 and (line2) 1FB297
Having in mind that the radio says BFB297, should I have for backup purposes the ones listed in kc9hi site? (he only has BFB297)
I can't find the HN5RV01-1FB297.img file.
Thanks again.
Marcelo
