Hi!
Well, I'm new in this forum, I read many very useful threads here, so at first thanks for sharing.
I'm a question about my UV5R (Ver BFB297).
I read in some sites that when TDR (menu 7) is ON, the radio should Tx on the last A or B that received transmissions, so to avoid that, we can set a fixed A or B for our Tx in menu 34 TDR-AB.
...well...mine doesn't keep in the last A/B that received...always remain in the one I select....either if I set OFF - A or B in menu 34. No matter what menu 34 option, always transmit in the one I select with the A/B key.
Is that a change in BFB297 or a bug?
Also I take advantage of my post to ask to be sure....the "recovery" images to reset my version are these?
- BFB297 Reset.img
- BFB297(factory).img
...both downloaded from: Index of /uv5r/programming/CHIRPrecovery
Are them the correct?
Thanks in advance.
Marcelo (KAOS)
- BFB297 Reset.img
Thanks in advance.
Marcelo (KAOS)
