KK4ELO
I have an antenna that came on a truck I bought a long time ago and I was wondering if I could use it for 2m and 440. It's an antennex brand and it says its 132-525. Is that the actual bandwidth, or is it one of the cut to band deals?
Ok.. I'm confused because it specifically says vhf AND uhf on the website.. Ok, so scanner antenna it is then thanks.
The whip itself is 16 inches pHow long is the whip?
If it's 1/4 wave, 18 or 19 inches or so will make it resonate on VHF. If it's around 6", it'll be resonate on the UHF band.
The base is not necessarily a loading coil.
What you have is a wide band 1/4 wave antenna. With the 16" whip and the length of the spring, it's tuned for likely the 154MHz range.
If it was resonate on the 2 meter band, it would act as a 3/4 wave UHF antenna on 70cm. Not a perfect dual band solution, but it will work with a funky radiation pattern on UHF. I've done it before with VHF quarter wave antennas.
