LandsdowneScannerGuy
- Joined
- Aug 2, 2022
- Messages
- 12
Most NMO antennas need a ground plane so make sure you have it if the antenna needs it. Also, PVC pipe turns to crap rather fast in direct sunlight. I would recommend painting the PVC pipe if its going to be outdoors for very long.
Grey PVC electrical conduit will handle UV exposure better than white irrigation type PVC pipe.
At 10 feet tall, you'll need something like 1 1/4" pipe if you want it to be somewhat rigid and not flop around.
EMT (metal) conduit would solve both the UV and floppage issues.
Get an NMO base adapter that has the ground radials. Even if you are using a dual band antenna that doesn't require a ground plane, it'll work better with one.
Sink the end of the conduit into a bucket full of rocks, dirt or concrete and it'll probably work pretty well.
Other option would be to get a large tripod. More money, but easier to set up and haul around.
I believe this is the sort of thing mmckenna is talking about for using an NMO mount antenna in a base situation:
Here's a Laird available from an Amazon seller: Laird MBCExactly, except NOT Tram/Browning or any of the Chinese brands.
And, from The Antenna Farm: Laird Connectivity MBC
Do you need the junction box hanging off the top, on one side? Why not just throw an endcap on the pipe and the NMO on that, or utilize the box at the top of the PVC as the mount?
Ya. I used brazing rods. They are something like $0.40 each and are 3’ in length, so if you bend them 90 degrees and attach one on either side of the mount with a self tapping metal screw, you end up with four radials of approximately the right length.If the OP wants to go cheap he could make radials out of coat hangers and use a screw and washer to hold them down to his outlet box. Or mount the NMO to some thin sheet metal and solder or bolt the coat hangers to that. It doesn't need to be pretty to work.
This is what I would get based on what you describe (the N model). Much more substantial counterpoise and built in pole mount. No electrical box required. It’s not the cheapest solution, but it’s nice and clean and it’s made in the USA.
COMPACTenna COUNTERPSE-N COMPACtenna CompacCounterpoise NMO Mount Base Station Ground Plane | DX Engineering
Free Shipping - COMPACtenna CompacCounterpoise NMO Mount Base Station Ground Plane with qualifying orders of $99. Shop Mobile Antenna Mounts at DX Engineering.www.dxengineering.com
-B
On this note, sometimes the 7/800MHz version is significantly cheaper and they are usually less to ship as the radials are only 4” long… the important part is the mount with the radial holes. The radials are held in place by set screws and you can easily buy music wire of appropriate diameter, cut to length and leave the 7/8MHz radials in the box…Here's a Laird available from an Amazon seller: Laird MBC
So, I'm assuming you mean do something like the picture below (looking from the top, yellow disk being the NMO mount, the 2 silver disks being screws/washers, and the brown lines representing the radials).
That would work and its cheap and dirty. Mostly dirty.
At that price point ($110), I'd just as soon get a dedicated base antenna!This is what I would get based on what you describe (the N model). Much more substantial counterpoise and built in pole mount. No electrical box required. It’s not the cheapest solution, but it’s nice and clean and it’s made in the USA.
