I tried the instructions from the 2021 link. Could not get the R8600 working with SDR++.
Is there a trick using newer versions of all of the programs that the snipets of components used to make the radio work?
I'd like to try satdump. I see that SDR++ can be used with it through a tcp link.
SDR++ and Icom IC-R8600
I have managed to make SDR++ Windows X64 version work with the IC-R8600. To do so I originally got the 8600 working with another SDR program, SDRGlut. Then, I copied the following files from SDRGlut over to SDR++ SoapySDR.dll SoapySDRUtil.exe ExtIO_ICR8600.dll icr8600Support.dll was copied into...
forums.radioreference.com
